pressing the steering column sleeve and bearing
158,000 MILES • 1.9L • 4 CYL • TURBO • 2WD • MANUAL
JC1WAY
  • 11 POSTS
I depressed the bearing use a split bearing puller. Replaced the ignition switch. I cannot get the sleeve and bearing to press enough to get the steering wheel back on. I tried using the steering wheel bolt to tight and press the sleeve and bearing.
Nov 26, 2016 at 3:15 PM
  • 55,851 POSTS
Hey Jc1way,
Sometimes what happens is the steering shaft gets pushed down into the column which it is suppose to do during a crash. You might need to force the shaft back upward to get the correct length to put things back together.
Please let us know happens so it will help others.
Best, Ken
Dec 1, 2016 at 2:02 AM
