Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Scion
xD
Engine
Symptoms
Low Power
Press accelerator will not move
2008 SCION XD
113,000 MILES • 4 CYL • 2WD • AUTOMATIC
MARCI RICHMOND
MEMBER
1 POST
Runs at idle. Three codes come on. Changed accelerator pedal, reads low voltage. Never happened before. Cannot drive it. Help please.
Oct 19, 2018 at 1:33 AM
Experienced Mechanic
The car is in limp mode which can be caused by a dirty throttle bore. Start by disconnecting the battery and then follow this guide.
Clean it thoroughly and then clear the codes and see what happens.
https://youtu.be/ahK_eucFi-k
Cheers, Ken
Oct 20, 2018 at 4:33 AM
Add image or video
Ask a new question
Engine has low power
