comes on erratically and goes away, what is the problem and what is the repair?
Apr 21, 2013 at 12:21 PM
✓Experienced Mechanic
What comes on erratically? need detailed info to be of help.
Apr 21, 2013 at 7:22 PM
PETER TORRILLO
MEMBER
pre-safe comes and goes off erratically, car will not shift beyond 2nd speed and check engine light coms on. This situation will exist temporilly and then car will act normally.
Apr 21, 2013 at 10:56 PM
Scan engine and trans for unresolved fault codes the check light is indicating a fault code is present.
