Power Windows Running Slower Than Normal?
196,905 MILES • 3.4L • AUTOMATIC
RALPHPHIPPS22
  • 37 POSTS
I have an issue where my power windows run slowly even after a new regulator was put in. I tried greasing the tracks and it didn’t help with it. I’m thinking something is not getting enough power or ground
Jul 24, 2026 at 10:26 AM
  • 55,746 POSTS
It can be you got a defective window motor regulator replacement, can I ask where you got the replacement part from? Did the old window operate the same way before it broke? If not chances are the new regulator motor is bad.
Jul 25, 2026 at 7:43 AM
