Power windows problem
160,000 MILES
VINNIEV
My power windows only work when the drivers side door is open all the way. When I close the door I can hear a sound like the power locks are engaging and then disengaging. The locks do not really lock and unlock, but I can hear the sound that it usually makes. Something seems to be disabling the power windows when the door is closed. I appreciate any help you could provide on this very frustrating problem. Thank you!
Vinnie
Jan 16, 2017 at 2:24 AM
SATURNTECH9
  • 30,869 POSTS
Sounds like you have a broke power feed wire in the boot that goes from the body of the car to the door. The power feed wire is much larger and does not flex like the other wires. So over time opening and closing the door the wire breaks. that is where I would start looking.
Jan 16, 2017 at 4:45 AM
VINNIEV
Thank you! Do you know the color of the wire that is the power feed wire?
Jan 17, 2017 at 6:26 AM
SATURNTECH9
  • 30,869 POSTS
Looks like black it be noticeably larger then the rest and probably visibly broken.Pull the boot back and have a look at it.
Jan 17, 2017 at 7:10 AM
VINNIEV
Thank you! You were right! I really appreciate your help!
Jan 19, 2017 at 3:57 AM
SATURNTECH9
  • 30,869 POSTS
No problem glad you found it please tell your friends about our site.
Jan 19, 2017 at 4:07 AM
