power windows not working
153,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
WILLISIN
I replaced master switch still not working.
Jan 7, 2022 at 3:41 AM
SQM
  • 6,383 POSTS
First item you want to check when a window is not working is the fuse.
Have you checked it?
There is a 25A circuit breaker located on the fuse panel at the end of the dash inside the vehicle.
If the circuit breaker is good, then the issue could be a window motor or regulator. It can also be due to faulty wiring.
Does any window operate? from any switches?
Let me know a few more details of what you are experiencing.
Jan 7, 2022 at 12:26 PM
  • 110,246 POSTS
The first thing I need you to do is check for power at the red wire with a white tracer at the driver's door main switch. The power to the switch is supplied via a circuit breaker that may have failed. If there is power, then confirm the black wire at the main switch has continuity to ground. Here is a link that you may find helpful:
If you look at pic 3, it shows the circuit breaker location in the fuse box.
If you find no power at the red/white wire, check the circuit breaker, making sure there is power to it and from it.
See pics below. Note: Pics 1 and 2 are the wiring schematic for the windows. I had to cut them in half to make them readable. I did overlap them.
Jan 7, 2022 at 12:41 PM
WILLISIN
i completed a test and i have current to my master switch drivers' side, the window on front passenger side will operate using that switch i have 2 fuse boxes on my truck listed above i have tested all fuses both under the hood and inside the cab. i have a few fuses both inside the cab and under the hood not showing any current. pulled and checked all fuses and they are fine. I will wait for response. thank you
Jan 8, 2022 at 1:22 AM
WILLISIN
oh, i forgot drivers side and rear passenger windows will not work independently.
Jan 8, 2022 at 1:25 AM
  • 110,246 POSTS
Let me know which fuses don't have power. That way, I can trace them back to see where the power is coming from. Something before the fuse must have failed.
Jan 8, 2022 at 3:23 PM
