Power windows issue
268,000 MILES • V8 • 2WD • AUTOMATIC
NASER NASER
  • 836 POSTS
just realized none of the windows work; no clicking heard when holding any of the switches up or down. tried at main switch and at each window..few days ago was checking fuses for radio and found all to be good, not sure if this happened after.. might be a relay or a fuse, if you can pinpoint to their location I would appreciate it..
May 7, 2020 at 4:39 AM
NASER NASER
  • 836 POSTS
this is the one with the 4.7L.
  • 110,251 POSTS
Naser,
I attached the entire power window schematic. The fuses/relay are in the first pic. I overlapped them so you can follow them easier.
If the fuse and relay are good, check for power to the pink wire (which changes from brown) at the driver's master window switch.
Let me know if this helps.
May 7, 2020 at 1:03 PM
NASER NASER
  • 836 POSTS
Already checked pink wire, no power. Fuse 30a under left side of dash is okay.
May 7, 2020 at 1:08 PM
  • 110,251 POSTS
Either the relay is bad or there is an open in the wire. The fuse supplies power to the relay. Check to see if there is power at the brown wire off the relay.
May 7, 2020 at 2:23 PM
NASER NASER
  • 836 POSTS
I can't find the relay.
May 7, 2020 at 11:25 PM
  • 110,251 POSTS
It should be in the fuse/relay panel on the left side under dash. That is what it indicates in the schematic. If there is a rear power window, it shows that one either under the hood or behind the seat based on if it is an extended cab.
Naser, it doesn't indicated it in the schematic, but I'm questioning if it is one that is a built in (PCB).
May 9, 2020 at 12:59 PM
NASER NASER
  • 836 POSTS
This is extended cab, none if the 4 windows work whether from main switch or each window's switch, not even a click sound. I checked every fuse under left side and all good. Can't find any relays.not sure really.
May 9, 2020 at 1:06 PM
  • 110,251 POSTS
I attached a pic below. I suspect I know why you can't find the relay. I believe it is part of the PCB in the body control module. See pic 1
Naser, I attached two more pics. I highlighted everything from left to right. Pic 2 is the upper portions of the two pages and pic 3 is the lower. I did it this way because I could highlight things differently allowing you to see the system in a more understandable way.
May 9, 2020 at 1:58 PM
