Power windows fail, pull battery terminal, it works?
275,000 MILES • 4.7L • V8 • AUTOMATIC
JOHN GRIFFIN
Power windows stop working, then we pull the battery terminal & it works, looking for root cause to permanently fix
Feb 11, 2023 at 12:37 PM
  • 55,746 POSTS
Hi John,
Usually, it will be the driver's door module but there is an outside chance it is the BCM or passenger door module here is the window wiring diagrams so you can see how the system works and how to replace the DDM in the images below please let me know how it goes.
A multiplexed door module is located on each front door driver door (DDM).
Thanks for using 2CarPros.
Feb 16, 2023 at 2:37 AM
