There should be a power window circuit breaker, right side of dash, fuse box. On any fuse or circuit breaker, you have to use a voltage tester on the circuit, even if the fuse/breaker is ok, if there is no voltage, the circuit is dead.
All window controls go through the master switch, driver side door. I'd want to check main voltage and ground for the master switch. Voltage is yellow wire, black is ground. The wires that go into the driver door, hinge side, is probably covered by a rubber boot, sometimes you can pull the boot back far enough to check the wire colors I mentioned. The yellow wire probably goes hot, when you turn on the key. If you check the c/b circuit, the key probably needs to be on for the circuit to go hot.
Jan 8, 2020 at 4:36 AM
(Merged)
