Did you check for power on both sides of the fuse?
Another common issue is the wiring in the front door. there is a rubber boot when you open the door that contains all the wiring for the windows and the dome light. from all the years of opening and closing, the wires can break from constant bending.
try cutting open the boot and inspect the wiring for any damage.
Apr 22, 2018 at 11:15 PM
