The passage side window wont roll up after I rolled it down. I changed the power switch, but that did not work.
Jun 21, 2016 at 1:51 AM
SATURNTECH9
✓Experienced Mechanic
When you try to roll the window up if you put your ear on the door can you hear the window motor click or make any noise? You could have a bad window motor.
Jun 21, 2016 at 3:53 AM
JOHNNY G.JR
while holding switch down try tapping on door panel sometimes works ,bad contacts on brushes inside of motor.
Jun 21, 2016 at 12:55 PM
Here is a guide that can help you get an idea on how to change it.
