Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Carina
Body
Window
Not Working
Power windows
1994 TOYOTA CARINA
120,000 MILES
CRAIG SPENCE
MEMBER
1 POST
Passenger window not working and can't control from driver door.
Dec 20, 2018 at 4:56 AM
Experienced Mechanic
It sounds like you have a window motor that is out. but to be sure here is a guide that will explain how to check to confirm the issue:
https://www.2carpros.com/articles/electric-window-repair
If the motor is bad this video will give you step by step even though it on a similar car the steps are the same.
https://youtu.be/Wp7Ak9IGs4o
Dec 22, 2018 at 6:13 AM
Add image or video
Ask a new question
Engine won't start
