Drivers window will not operate until the temperature go to about 70 degrees or lower. Will not work all summer. Once the fall comes it will work all winter and spring until it gets hot out. It has been like this for two years now. I replaced the switch in the door. Any ideas? Also had a Chevrolet Cavalier with same problem. Thank you
Sep 14, 2016 at 8:57 PM
