power window wiring boot and sleeve
2006 SATURN ION
157,000 MILES • 2.2L • 5 CYL • MANUAL
AMARIEO1970
My windows don't work. My sun roof does. I have replaced the switch in the drivers side door. The windows all quit working the same day. There are no fuses out. I am mechanically inclined. I was quoted 1500.00 per window at the dealer to fix my issue (which I thought was insane). I know if I cut the sleeve in the door I will need to be able to waterproof it again. I have jiggled the boot and played with the switch. If you can give any advice that would be great. Thank you in advance :)
Angela
Apr 11, 2015 at 3:06 PM
SATURNTECH9
  • 30,869 POSTS
Do you have a multi meter to do some testing? That way we can do some testing.
Apr 11, 2015 at 5:57 PM
AMARIEO1970
we used a multi tester in the power window switch and wiring to see if it was a ground issue. There was no power coming to the switch.
Apr 12, 2015 at 10:01 AM
SATURNTECH9
  • 30,869 POSTS
Alright me see where the power goes on that car.
Apr 12, 2015 at 4:08 PM
