It has manual locks and windows. I have added power windows and locks withe the factory door harnesses.
I have not been able to locate a dash harness that has all of the same connectors ( plugs ) as mine has. I have pulled a few! And every BCM is different as well. So......
Is there a diagram of the actual switch pins for :
DS window switch
DS lock switch
DS power window switch
PS window switch
PS lock switch
If I can find out what each pin controls I can make the correct connections and add relays where needed
Hope this was enough info?
Thanks
DS window switch
DS lock switch
PS window switch
PS lock switch
Thanks
Apr 15, 2015 at 12:55 AM
