Power window malfunction
1992 OLDSMOBILE
200,000 MILES • 3.1L • 6 CYL • FWD • AUTOMATIC
STEVEN SCOTT HEBB
I pull into driveway,before shutting off motor, try to roll up Windows and nothing happened. None of regular see-thru fuses not blown.power is flowing to switches in driver side door, other door switchs non-responsive.
Jun 5, 2016 at 12:30 PM
HMAC300
  • 48,601 POSTS
wiggle harness in driver door it may have a broken wire. if that doesn't work slam door hard if window goes up motor is going bad. then check for power getting to motor or not. it may still be a wire broken due to age of car
Jun 6, 2016 at 12:32 AM
