Power window malfunction
1992 OLDSMOBILE CIERA
200,000 MILES • 3.1L • 6 CYL • FWD • AUTOMATIC
STEVEN SCOTT HEBB
I pulled into driveway, before shutting off the engine I try to roll up the windows and nothing happened.. None of regular see-through fuses are blown. power is flowing to switches in driver side door, other door switches non-responsive.
Jun 4, 2016 at 9:47 PM
HMAC300
  • 48,601 POSTS
check harness between door and jamb might have a broken wire. then check switch to see ifit works or not. you might have a junction block on lh side of dash or behind kick panel and may not have power through there
Jun 5, 2016 at 1:36 AM
