Power window fuse panel diagram needed
97,000 MILES
KEITHWADE30135
Power window relay, gets hot. Windows will not roll down. Is there a separate fuse besides the 30 amp relay?
Apr 20, 2020 at 10:52 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is the power window wiring diagram you requested.The relay getting hot leads me to believe you have a possible wiring short to ground.Here is a wiring test tutorial for you to view:
I've attached the picture below.Hope this helps and thanks for using 2CarPros.
Apr 20, 2020 at 11:24 AM
