Power window drivers side
200,000 MILES
JLMEHAFFEY
I recently replace my interior door handle on my truck. Once I got everything put back on the left side of my window will not roll down and looks like it is catching on something. I looked inside the door to see if I could see anything but I can’t find what it could be catching on. Any ideas?
Feb 10, 2020 at 9:07 AM
  • 110,248 POSTS
Do you have power or manual windows? Also, does the window move at all? If it does, does it tilt when moving before it stops?
Feb 10, 2020 at 10:26 AM
JLMEHAFFEY
Power windows and yes it moves and tilts before stopping. The right side goes further in than the left side.
Feb 10, 2020 at 10:39 AM
  • 110,248 POSTS
It sounds like either it is off track or the regulator is damaged. If you loosened any of the nuts on the door when you had the panel off, you may have taken the equalizer out of adjustment.
I'm going to provide the directions for replacing the glass. It includes the regulator, adjustment, and so on. Take a look through it. Pay most attention to the equalizer bracket nuts and make sure the regulator motor is tight.
You are not replacing the window, but these are the only directions I have that provide what I feel is needed. The attached pics correlate with the directions.
________________________
2002 Ford Truck Explorer Sport 4WD V6-4.0L VIN E
Removal and Replacement
Vehicle Windows and Glass Windows Window Regulator Front Door Window Regulator Service and Repair Removal and Replacement
REMOVAL AND REPLACEMENT
Heavy Duty Riverter
Pic 1
SPECIAL TOOL(S)
REMOVAL
1. Raise the front door window glass to the full up position.
2. Remove the interior door handle.
3. Support the front door window glass.
pic 2
4. Disconnect the front door window regulator motor electrical connector.
pic 3
5. Remove the equalizer bracket nuts.
pic 4
6. Remove the front door window regulator.
1 Remove the rivets.
2 Remove the nut.
pic 5
7. Remove the front door window regulator motor.
1 Remove the bolts.
2 Remove the front door window regulator motor.
INSTALLATION
1. To install, reverse the removal procedure.
^ Use the special tool to install the rivets.
^ Cycle the door glass to make sure of engagement of the drive mechanism.
_____________________________
I have a feeling something was left loose by accident.
Let me know if this helps.
Feb 10, 2020 at 11:33 AM
