power window all but driver's do not work?
104,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
PACEVETTE
The driver's power window panel operates on all four windows but the individual ones on each door stopped working all at the "same time" I am pretty sure.
Oct 23, 2022 at 7:39 AM
MIKE H R
  • 3,094 POSTS
the power goes to the driver's side and then goes to the other windows, you might have a bad connection, take the power switches out of the door by popping it up, careful of the clips. You can disconnect the wiring harness then use electrical contact cleaner and clean the connections. It may be getting no power going to the other motors. have seen it happen a couple of times where the contacts get loose and do not work properly. If that does not take care of the problem, it may be the driver's side window control that is causing the problem.
Mike
Oct 24, 2022 at 1:54 AM
