Driver's side power window not working
168,567 MILES • 2WD • AUTOMATIC
APRILSMITH02
  • 5 POSTS
All my windows work except the driver's window. The button seems to be broken. Do I just need to change the button?
Mar 18, 2022 at 12:26 PM
SQM
  • 6,383 POSTS
It is possible for the switch to be bad or have a loose connection.
First you want to make sure that it is the button and not a wiring issue.
You will need to check to see if there is power to the switch.
Here is a helpful guide on how to test the window switch:
https://www.2carpros.com/articles/electric-window-repair
I have attached diagrams showing how to test the switch for your reference.
Mar 18, 2022 at 3:15 PM
