power window
220,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
FIXITMR
  • 9,989 POSTS
my passenger power window suddenly stopped working. I think it was an overnight thing. window is up/shut. had no previous sign of malfunction. neither switch/button has any effect. I am assuming all parts are original.
Sep 7, 2017 at 12:40 AM
SATURNTECH9
  • 30,868 POSTS
If you put your ear up against the door while operating the window switch can you hear any clicking etc inside the door?
Sep 7, 2017 at 6:02 AM
FIXITMR
  • 9,989 POSTS
ok i just tried with door open and window WORKED! i know i tried today with door shut did NOT work. maybe its a wire problem in door hinge?
Sep 8, 2017 at 12:45 PM
SATURNTECH9
  • 30,868 POSTS
Yes the wire that goes thru the boot to the door inside that boot is broken.
Sep 8, 2017 at 3:08 PM
