Power-train and SRS alert
200,000 MILES • 3.8L • V6 • 2WD • MANUAL
STEPHEN DEANSHAW
SRS alert sounds as after starting,check power train light comes on after about thirty minutes of driving. temperature normal, drives fine. Is hot though. topped radiator off. ran check bleed screw ECT, but still doing same. after removing battery terminals to rest and see what comes back and same two alerts. Help.. Just swapped my super sports Suzuki for this 2006 vz Crewman Ute might have just blown $8,000.00. I am very mechanically minded but need some serious help peoples. Please!
Jan 16, 2018 at 11:54 PM
  • 55,746 POSTS
We can get this fixed up for you. Lets start by reading the SRS codes and the check engine light codes. Here is a video and a guide to help you see what to do to get started:
and
https://youtu.be/gnSGfEqrf_w
Cheers, Ken
Jan 18, 2018 at 2:28 AM
