Power train
5,000 MILES • 3.2L • 5 CYL • TURBO • 4WD
RICK RAMSINGH
Power train light keeps coming on how do I clear it?
Apr 3, 2017 at 12:52 PM
CARADIODOC
  • 34,415 POSTS
Have the diagnostic fault codes read and recorded. Diagnose the circuit indicated, repair it, then erase the codes. The people at many auto parts stores will read the codes for you for free. Be aware those codes never say to replace a part or that one is defective. If a part is referenced in a code, it could be the cause of that code, but about half of the time it is a wiring or connector terminal problem instead.
Apr 3, 2017 at 1:02 PM
STEVE W.
  • 15,419 POSTS
Have you been able to repair your vehicle or found the problem? Please post back as you may help others with your repair. Thank You.
Steve
Apr 7, 2017 at 3:35 PM
