No acceleratation
20,003,456 MILES
NANDIN1972
I have no acceleration. I had catalytic converter problems took care of that and now this problem off no engine power whatsoever.
Feb 9, 2018 at 8:45 PM
Good morning.
Have you checked the fuel pressure? common issue for no power.
With high mileage, has the timing chains been checked? you can check by performing a compression test.
Also, did you replace both converters?
Feb 10, 2018 at 4:51 PM
