What is the correct power steering fluid for the van?
97,000 MILES • 6 CYL • 2WD • AUTOMATIC
TOYPACIFIC
  • 159 POSTS
Hi, I'm just trying to find the correct power steering type for this year make and model.
I apreciate this in advance..
Thank you
Jan 23, 2021 at 9:41 AM
STEVE W.
  • 15,370 POSTS
Honda/Acura tends to be somewhat picky about the power steering fluids used due to the materials used in their steering systems. To prevent issues with them it is best to use the Honda fluid 08206-9002. There are some companies who make "Honda compatible" but for the price difference and what it would cost in repairs if the fluid wasn't fully compatible the Honda fluid is very reasonable. The system holds about 1.25 quarts total so 4 of the 12oz bottles will do a refill on a dry system. If you are intending to flush the system it isn't hard, use a suction device like a turkey baster or suction pump to remove as much fluid as possible from the reservoir. Then disconnect the return line (top line on side of reservoir) and plug the connection on the reservoir, connect the open line to a hose so you can direct the flow into a container. Start the engine and with it at an idle, turn the steering wheel lock to lock slowly. Once fluid stops coming out, refill the reservoir with new fluid and repeat the process. Refill again, that should exchange most of the fluid. Reconnect the return line and purge the system of air by turning the steering wheel lock to lock and raising the engine rpm to 1,000-1,500 RPMs. Top off the reservoir and you are done.
Jan 23, 2021 at 4:43 PM
TOYPACIFIC
  • 159 POSTS
Thank you. I was looking for the type of fluid but you gave me spot on information.. I appreciate this very much.
Thank you
Jan 23, 2021 at 5:17 PM
STEVE W.
  • 15,370 POSTS
You are welcome. Thank you for using 2CarPros.
Jan 23, 2021 at 11:45 PM
