The issue you are having trying to find this is most likely because it is sold as part of the pump. They show how to remove it for cleaning purposes.
Yes. Low fluid will cause a whine to the pump. It should only be changed when the fluid smells burnt. This is not a common requirement but if the pump or other component in the steering system is changed, it is a good idea to flush the fluid.
Nov 3, 2019 at 7:17 AM
