On this vehicle with the 2.4 l eng it has eps (electronic power steering ) so theres a motor and a controller one of them could be having trouble could be either one on this vehicle i believe its mounted directly to the steering column the shaking/vibrating is usually caused by a failing motor or controller ..but sometimes it can be a loos ir corroded power or ground source or evan just be re calibrated and work just fine after that...
That said" I think in this case you might want to take it to a shop that has a decent scan tool so they can maybe scan it put it up on a lift and get a better look at it ..usually they can give you a good estimate and alot more insight as to what the problem might be in a reasonabley short amount time ...but if you do you might ask them first if the have a good scan tool that can perform these procedures not all of them can
Hope this helps giod luck
Nov 16, 2026 at 11:22 AM
