Where is the power steering pump located?
250,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
NATHANLIND0
I was watching the 5.3 lm7 rebuild one of your guys posted last year and I'm following the same footsteps of parts used. But i have not found/seen a bracket to connect to the tension pulley for the power steering pump as I will be reinstalling the engine back into the original truck.
Am I overlooking or is there no possible way to bolt on the power steering pump again?
Oct 19, 2022 at 11:26 AM
RYAN L
  • 273 POSTS
Hey there!
Thanks so much for watching and for using the site! If I were you, I would just use all the stock brackets if you still have them.
Let me know!
Best,
Ryan
Oct 20, 2022 at 6:23 AM
