Power steering pump keeps going out
190,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
MATTHVACKC
This is the third power steering pump in just over a year. I am curious if it is the high pressure hose or bad rack and pinion itself.
Jul 15, 2018 at 12:23 PM
  • 110,246 POSTS
If you are purchasing an aftermarket re manufactured pump and it keeps happening, chances are it is nothing more than a bad pump. However, when you replace the pump, you should flush the old fluid from the rack and pinion as well as the lines to prevent dirt from re-entering the new pump. And yes, I have seen issues where the hoses have deteriorated internally and caused pump problems.
If you have been using the same brand each time, try a different brand and make sure to flush the system before refilling and bleeding the system. Here is a link which discusses power steering problems:
https://www.2carpros.com/articles/power-steering-problems
How to flush the system:
https://www.2carpros.com/articles/power-steering-fluid-flush
Here are general directions for pump replacement which may include something you have overlooked.
https://www.2carpros.com/articles/how-to-replace-a-power-steering-pump
If you have other questions or need additional information, let me know.
Jul 16, 2018 at 1:27 PM
