Power steering pump
168,000 MILES • 3.9L • V6 • 2WD • AUTOMATIC
ZMCGEE62
  • 5 POSTS
I replaced the power steering pump because it was making a metal on metal grinding sound when I turned the wheel especially when it is warm outside. My car is the base model. It is still making the sound but not as bad. Could there be something else wrong or did I get a bad power steering pump to replace it?
Jun 4, 2018 at 10:54 AM
  • 110,248 POSTS
Hi and thanks for using 2CarPros.com Before I can try to answer that question, are you certain the sound is coming from the power steering pump? There are other belt driven items that can make that noise including the belt tension-er and idler pulley.
Thanks,
Jun 5, 2018 at 11:00 AM
ZMCGEE62
  • 5 POSTS
A shop told me the pump was going bad and replacing it would fix the sound. The metal on metal sounds happens when I turn the steering wheel when it is warm outside. When it is around seventy degrees or below outside, it does not make the sound at all. The new pump does also make a whining sound when you turn the wheel, but I have been told that is common with these types of cars.
Jun 6, 2018 at 1:11 AM
  • 110,248 POSTS
Hi again,
I have to be honest, if it does the same thing as the old one, I feel it may not be the pump. As far as the whine you hear, that is very common on re-manufactured and aftermarket pumps. They are never as quiet as the OEM pump.
The only thing I can think to tell you is to get a second opinion to confirm it is the pump. Usually, if there is an issue with the new pump, usually is does not mirror the old pump. I have thought about maybe a pressure issue, but that would not be affected by temperature.
One other thought. Is it possible for you to video the noise when it happens and upload it for me to hear? It may help point me in a different direction. Also, open the hood and make sure the serpentine belt is even on all pulleys. I have a feeling it is an idler pulley or tension-er pulley.
Jun 6, 2018 at 9:30 AM
ZMCGEE62
  • 5 POSTS
I do not think it would be the tension-er pulley. I had that replaced a couple years ago and it still feels tight. I uploaded a video of the sound. You can hear the cracking behind the whining sound when you turn up the volume. The sound happens when it is warmer than 80 degrees outside and when I turn the steering wheel either way. Hope this gives you a better idea and thanks for your input.
Jun 27, 2018 at 12:07 PM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
The sound in your video makes it seem like the noise is coming from a suspension component. Have you had any front end components replaced? ( Bushings, ball joints, tie rod ends) or are they original? Sounds like noise is when turning the steering. Ford steering pump noise is common, just maintain fluid level.
Jun 27, 2018 at 12:47 PM
ZMCGEE62
  • 5 POSTS
As far as I know all those components are original and yeah, the noise only happens when turning the steering wheel either way.
Jun 28, 2018 at 12:49 AM
DANNY L
  • 5,648 POSTS
Danny here.
Yes, it sounds like a component in the front end suspension. It is hard to diagnose a sound via emails without seeing/hearing the car in person. It would be best to have car put on a hoist to put up in air to physically inspect with someone turning steering wheel to mimic sounds while inspecting. I would thing it is about time for front end work to be done with having 168,000 miles due to normal wear and tear. Hope this helps.
Danny-
Jun 28, 2018 at 11:58 AM
ZMCGEE62
  • 5 POSTS
Sounds good. I will look into it further. Thanks again!
Jun 29, 2018 at 12:19 AM
DANNY L
  • 5,648 POSTS
Danny here
You are welcome! Thanks for using 2CarPros.
Jun 29, 2018 at 9:11 AM
