power steering pump
FORD MUSTANG
MONTYG5
  • 8 POSTS
I have a 1989 GT Mustang 5.0 hatchback and im replacing the power steering pump but cant figure out how to remove the hose that connects from the side its like a presssure line or something can anyone please help me out thank you!!!!!!!!!!!!!
Mar 2, 2007 at 2:50 PM
TAURUSWHEEL
  • 718 POSTS
I think you unscrew the tube nut.. be careful and use a tube-nut wrench, and don't over tighten the nut on re-installation, if it gets damaged you'll have to replace the entire hose assembly.. there is a plastic or nylon type seal in there that is supposed to be replaced if you remove the line,,, easiest way to get it over the threads is stretch it out larger on a punch or something similiar, install it and it will shrink back down,
Mar 2, 2007 at 3:24 PM
MONTYG5
  • 8 POSTS
Well im getting a new pump do you think that seal come with it or should i try to find one
Mar 2, 2007 at 3:44 PM
