How to remove Power steering pulley without a special tool?
180 MILES • 3.0L • 6 CYL • 4WD • AUTOMATIC
AGSIPE
How do you get a power steering pulley replace without that special tool
Mar 14, 2023 at 12:14 PM
  • 110,248 POSTS
If you try prying it off, chances are it will break that really doesn't matter if you are replacing it. However, you need the pulley tool to reinstall the new one.
Most parts stores will lend this tool to you at no charge. Watch this video. It explains the procedure.
https://www.2carpros.com/articles/how-to-replace-a-power-steering-pump
I wish I had a better answer, but the tool is needed to both remove and reinstall the new one.
Mar 14, 2023 at 2:56 PM
