Good morning.
Instructions below.
Removal
imageZoom/Print
1. Disconnect the battery ground cable.
2. Remove the power steering pump reservoir.
imageZoom/Print
3. Remove the (A) bolts and position the (B) power steering pressure hose aside.
imageZoom/Print
4. Remove the (A) bolts and position the (B) power steering pressure hose support bracket aside.
imageZoom/Print
5. Rotate the (A) drive belt tensioner to release the tension and remove the (B) drive belt.
imageZoom/Print
6. Remove the (A) generator bolts and position the (B) generator (GEN) aside.
imageZoom/Print
7. Use (A) Strap Wrench to remove the (B) pulley bolts.
8. Remove the power steering pump pulley.
Installation
Images (Click to enlarge)
Jul 1, 2018 at 11:22 PM
