power steering not working
149,000 MILES
JUNKMANJR
I'm considering changing the rack and pinion from power to manual. Is there any reason I shouldn't?
The pump was dry when I purchased the car. I found a reman manual r&p for a decent price and figured I'd get a
bit better mileage without the pump dragging down the engine. Plus, even now without the power assist, it's pretty easy to steer.
Good idea or bad?
May 10, 2013 at 7:23 AM
SAMIR AYAD
i think
you should keep your power steering system
change the pump and check conections from pump to rack and pinion
to have easy steering
May 10, 2013 at 7:59 AM
  • 31,937 POSTS
Your choice really, i would be fixing the power steering, the pump load is near zero when driving, but there is no reason why you cant do this.
May 10, 2013 at 10:20 AM
