Power steering noises
156,000 MILES • 3.7L • V6 • 4WD • AUTOMATIC
KLHUDOCK64
  • 91 POSTS
When I start my vehicle listed above Limited model up and turn the wheel the whirring sound is loud. It seems after it warms up the noise goes away. Is this normal? I have only owned this 10 days. It didn't make any noise when I took it for a long test drive but it had been running for awhile. I don't know if this is normal or not. Anything I should check? I do not know where to begin. Thanks in advance.
Feb 15, 2021 at 12:32 AM
CARADIODOC
  • 34,415 POSTS
This is likely normal, but there's two things to look at. First, if the noise is coming from the power steering pump itself, Chrysler's parts department has a cold weather power steering fluid. That was mainly used in trucks with diesel engines but they use the same type of pump in other models.
Another problem that only occurs in cold weather is the steering shaft sticks to and rubs on the rubber seal on the firewall. That rubbing noise was common enough that they produced a service bulletin that included the fix. It was mostly on Neons, not on other models, but again, other models use a similar design. The repair involved unbolting the hard rubber boot on the firewall, under the dash. That is lifted up out of the way, then you can use a curved tool such as a pick or cotter pin puller to pull the seal back just enough to spray in some grease. The best grease for this is "Spray White Lube". That's Chrysler's name for what they have in their parts department. It's a lithium-based grease that you can also find at hardware stores and auto parts stores. It goes on very juicy and runny. The liquid soaks into tight places and takes the grease with it, then that liquid evaporates and leaves the grease behind. Unlike other greases, this stuff won't travel so it won't stain the carpet. It works really well for door hinges too.
Feb 15, 2021 at 3:52 AM
KLHUDOCK64
  • 91 POSTS
Thank you so much.
Feb 15, 2021 at 6:13 AM
CARADIODOC
  • 34,415 POSTS
Let us know if either of my suggestions was the solution.
Feb 15, 2021 at 7:35 AM
KLHUDOCK64
  • 91 POSTS
I certainly will. I have not checked for that grease yet. I live in Western NY and am currently in Northern PA so I warm the liberty up in this weather anyways. I have about 10 different projects going on right now between two different vehicles. I will definitely check it out though. I did talk to the original owner and he claims the liberty's power steering was like that from day one of him buying it.and that after its warmed up the noise leaves and it does. So it seems this is a normal abnormality for this particular 2004 Jeep Liberty Limited 4wd.
Mar 3, 2021 at 7:00 PM
CARADIODOC
  • 34,415 POSTS
There's a pressure-relief valve in the outlet port of the power steering pump where the high-pressure hoses is attached. That valve is what makes the hissing noise you hear when the steering system is turned as far as possible, then more pressure is put on the steering wheel. The power steering fluid gets thicker when it's cold, so it has more resistance to flowing freely. More pressure may build up in the hose leading to that hissing or buzzing. If you want to pursue this, as a test I would suck out some of the fluid from the reservoir, then replace it with that cold-weather fluid. If the noise is reduced, consider flushing the system and adding only the cold-weather fluid.
Here's a link to an article that will provide more information:
https://www.2carpros.com/articles/power-steering-fluid-flush
Mar 4, 2021 at 3:04 AM
KLHUDOCK64
  • 91 POSTS
Thank you. Yes it's one of those irritating noises that you have to turn the volume up. I will definitely check out the article!
Mar 4, 2021 at 12:16 PM
Good morning,
I would change the fluid as well. Old fluid will do this especially if it has some dirt or debris in the system.
Mar 7, 2021 at 7:51 PM
