Power steering leak?
160,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
AJB4691
Just noticed a slight leak on top of the power steering rack. I would like to add fluid with stop leak to see if that helps before going any further. Cannot find where to add fluid - no reservoir that I can see.
The vehicle listed above is a base model.
Thanks for any help you can offer.
Nov 7, 2022 at 8:21 AM
SATURNTECH9
  • 30,869 POSTS
You have an electric steering with a manual steering rack. They use an electric motor on the steering column for the power steering part. If you had a power steering pump on the engine you have it would be right on the side of the head.
Nov 7, 2022 at 1:04 PM
