Power steering hose is leaking
197,000 MILES • 4.2L • V8 • RWD • AUTOMATIC
HAAS HENDRICKS
So one of the hoses is leaking but I am going to replace both. are there specific names to the hoses I replace or can I just use a standard power steering hoses to replace both? Also, when I put pedal to the metal it takes awhile to get up in speed I was reading online and it was my fuel pump not giving enough fuel to the engine? Just need a second thought. thanks you guys.
Dec 31, 2016 at 10:20 AM
  • 31,937 POSTS
The hoses are usually referred to as the high pressure side and the low pressure side, hoses are molded to suit individual models so you must get the correct hose to suit your car. as for the power problem, start with basic tune up, plugs, filters etc and check for codes as well, not all codes will set a check light.
Dec 31, 2016 at 2:00 PM
HAAS HENDRICKS
Sweet, thank you. I will definitely start with that!
Jan 2, 2017 at 8:32 AM
  • 31,937 POSTS
Okay, if you need further assistance please repost.
Jan 2, 2017 at 7:16 PM
