power steering hose name
170,000 MILES • 4 CYL • 2WD • AUTOMATIC
TOYPACIFIC
  • 159 POSTS
i would like to know what the power steering hose in the rear bottom of the engine is called. i have a leak coming from that line. the one from the reservoir seems to be okay. i followed it down and noticed it dripping from the bottom lines, i purchased a pressure hose but i think i need the bottom lines. i just don't know what they are called.
i will attach a photo of the line i bought.
Sep 18, 2020 at 2:10 PM
  • 110,251 POSTS
Is it possible for you take a picture of where you see the leak and upload it for me to see? I don't believe the return like is run under the engine as you mentioned. However, I should be able to tell if I see it.
I attached the best pic i could find showing where the high pressure line attaches to the rack and pinion. Hopefully it will help.
Sep 18, 2020 at 2:16 PM
TOYPACIFIC
  • 159 POSTS
oh, okay. i see, yes i'm actually at work right now but when i get home i will take a picture and upload it. it might be later but no rush as soon as i get the photo that will probably help out a lot. thank you
Sep 18, 2020 at 2:20 PM
  • 110,251 POSTS
You are very welcome. I will watch for your reply.
Sep 18, 2020 at 2:56 PM
TOYPACIFIC
  • 159 POSTS
Okay, took some photos but apparently it says file type not allowed. I'm not sure why.
Sep 19, 2020 at 5:54 PM
  • 110,251 POSTS
What type of file are you uploading? Interestingly, you are the second person that said this to me tonight.
Sep 20, 2020 at 10:35 AM
  • 110,251 POSTS
Hi:
