Steering wheel vibrates when turning to the right?
125,800 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
DMACK00
  • 9 POSTS
So yesterday while I was driving, I noticed that my steering wheel starts to vibrate when I turn it to the right but when I turn it to the left it doesn’t. So today when I got in my car it still vibrated when it gets turned to right but my power steering goes out with it but when i turn it to the left it doesn’t go. I’m trying to figure out the problem. I recently just changed my front driver's tire. Would that cause a problem like this?
Feb 14, 2023 at 6:18 AM
  • 110,248 POSTS
By chance, is the tire you used as a replacement a different size? Is it a different wheel or anything different that the original one that was removed? It could be hitting something under the vehicle when you turn to the right.
Feb 14, 2023 at 8:39 AM
DMACK00
  • 9 POSTS
The tire I put on is 215/55/17 and the passenger side is 225/55/17.
Feb 14, 2023 at 8:46 AM
  • 110,248 POSTS
If the problem started after the tire replacement, that is where I would start. Keep in mind, you went to a smaller tire. Since these are both on the front, the drive axles are now required to turn at different speeds even when going straight. Turning changes, it even more. The larger tire turns slower, and turning right causes that to even be slower. I have a feeling that is the cause.
Let me know what you find.
Feb 14, 2023 at 9:19 AM
DMACK00
  • 9 POSTS
Yes, it started after the tire change. I made the change Friday and the vibration started Monday, but I noticed immediately it threw my steering off because I had turn more to right to keep me going straight. So, I’ll do a tire swap tomorrow and I’ll let you know if it fixes the issue.
Feb 14, 2023 at 9:25 AM
DMACK00
  • 9 POSTS
Hey, I have an update. I’ve changed the tire to the correct fit but it stills give a little vibrate when I turn to the right and my power steering proceeds to go out .
Feb 14, 2023 at 11:52 PM
DMACK00
  • 9 POSTS
This is the sound it makes when i slightly turn to the right.
Feb 15, 2023 at 3:34 AM
  • 110,248 POSTS
I heard something. It sounds like a slight rattle from a plastic component. Since the tire was replaced, has it improved? Also, when you lifted the vehicle, did you make sure the Jack was in the correct location? Sorry for so many questions. If I was there, I would automatically be checking things.
Feb 15, 2023 at 10:27 AM
DMACK00
  • 9 POSTS
No, I haven’t noticed no improvement after tire changed, for me to keep my car straight my steering wheel almost has to be at a 90-degree angle. Whenever my steering wheel centers my power steering goes out, I can drive a decent 10 mins without it going out until its center. I’m hearing the noise in the video from under the steering wheel where the main electrical components are located. I appreciate the questions, it’s no problem, I really appreciate you trying to help me with my problem.
Feb 15, 2023 at 12:03 PM
  • 110,248 POSTS
It sounds like something such as a tie rod was bent when the tire was replaced. When you lifted the vehicle to change the tire, where did you place the jack? If possible, take a pic of the location and upload it for me.
Also, place the steering wheel straight ahead. Stand a slight distance from the front of the vehicle and inspect both front tires. Do they appear to be equal in the directions they point?
Feb 16, 2023 at 8:52 AM
