Power steering gear box
174,000 MILES • 7.4L • V8 • 4WD • AUTOMATIC
JANAE MOORE
I just replaced the power steering gear box in my SUV but I can not figure out how to fill it with fluid. I filled the power steering pump but I am not seeing any bubbles or anything when I am turning the wheel. Not sure how to bleed this system since I am sure there is air and the gear box has no fluid.
May 27, 2017 at 1:47 PM
HMAC300
  • 48,601 POSTS
jack up front end then turn to lock one way hold for thirty seconds, repeat in other direction do that ten times should get air out , check fluid level when done. also, make sure lines are hooked up correctly.
May 28, 2017 at 1:05 AM
