Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Acura
MDX
Steering
Fluid
Flush
Power steering flush
2005 ACURA MDX
105,000 MILES
JAY BAKER
MEMBER
1 POST
What size hose did you use on the MDX to run to the drain pan? The hose that fit over the return hose. Thanks!
Aug 23, 2020 at 6:04 AM
Experienced Mechanic
I attached a YouTube video for you of the flush process.
I also attached a diagram of the lines and the joint you need to run to the pan.
https://www.youtube.com/watch?v=Ler8w5Itgyg
Image (Click to enlarge)
Jan 7, 2021 at 6:50 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
