Power steering fluid return line
200,000 MILES • 2.3L • 4 CYL • 2WD • MANUAL
JULIE MONIQUE BLACK
Where is the power steering fluid return line located?
Nov 3, 2019 at 2:53 AM
I attached the documents that you should need. Let me know if you need more information. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Thanks
Nov 3, 2019 at 9:15 AM
ROBERTROSE3000
Steering problem
2001 Chrysler PT Cruiser 4 cyl Two Wheel Drive Automatic
how do you replace it
Sep 27, 2020 at 5:30 AM (Merged)
IMPALASS
  • 3,112 POSTS
Hello –
To better assist you is your model just a PT Cruiser or a Limited or a Touring. Also, what is the size of your engine in liter?
Are you wanting to know how to replace the power steering pump or just the hoses?
