Power Steering Fluid Mix?
116,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
DSCHWINDT
  • 51 POSTS
I purchased a power steering fluid that is compatible with my vehicle, but when I went to add it to the reservoir, I noticed the fluid in the reservoir is red and the fluid I purchased is an amber color. Is it acceptable to mix these, or will I need to find a red fluid to add?
Nov 9, 2024 at 3:31 AM
  • 55,694 POSTS
Yep, you should be okay, it is normal for different manufactures to have different color fluids but so the same job.
Nov 9, 2024 at 8:29 AM
