Power steering fluid leak?
204,567 MILES • 2.3L • AUTOMATIC
CMOUA119
The power steering fluid in the resavoir is leaking out from the top more and more each time the car is driven. Can you tell me what's wrong? I'm thinking either the pump or the hose, but most likely if it's one your gonna wanna change both
Jun 10, 2026 at 6:45 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Confirm where the fluid escapes and have the fluid level, condition, connections and possible air entry checked before authorizing a pump. Follow the actual vehicle's fluid and bleeding requirements. Reservoir overflow alone does not establish the specific pump-seal failure asserted in the reply. The pump and hoses should be evaluated on the findings rather than automatically replaced together.
Guidance references and applicability
Source discussion: question 1712851 https://2carpros.com/questions/power-steering-fluid-leak-23843695--1712851 Supports the reported history and outcome only. Follow-up guidance is editorial synthesis; unverified specifications and diagnoses are not adopted. HELLA: Hydraulic steering pump https://www.hella.com/techworld/uk/technical/car-electronics-and-electrics/hydraulic-steering-pump/ General fluid, connection and air-removal background. Follow the actual vehicle's procedure; this source does not confirm a pump-seal failure.
Read the replies · Discussion summary and reported outcome
  • 55,837 POSTS
So, what happens is the pump main seal goes out and allows air to enter the system which forces fluid out of the top of the reservoir. I would replace the pump and problem should go away. Let me know if you need anything else.
Jun 11, 2026 at 7:10 AM
CMOUA119
Thank you! I will do that!
Jun 11, 2026 at 9:31 AM
  • 55,837 POSTS
You are welcome, let me know how it goes :)
Jun 12, 2026 at 9:46 AM
Discussion summary
The owner reported power-steering fluid escaping from the top of the reservoir during use. A contributor attributed this to air entering through a pump seal and recommended pump replacement. The owner intended to proceed, but no diagnostic measurements or repair outcome were reported.
Reported outcome: No pump replacement or successful repair was confirmed.
The thread does not document foaming, fluid specification, reservoir level, hose condition or a pump test.
Read the original discussion
