Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Saturn
Vue
Steering
Fluid
Power steering fluid change
2008 SATURN VUE
165 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
EDGAR456
MEMBER
Hi, do I have to use any special power steering fluid for my car listed above XE model? Or can I just use any?
May 8, 2018 at 8:49 AM
JIS001
Experienced Mechanic
Spec calls for GM power steering fluid. GM power steering fluid (Canadian) or equivalent.
For the most part clear power steering fluid should be okay as long as it is GM approved.
May 8, 2018 at 3:54 PM
EDGAR456
MEMBER
Should this be okay?
https://www.google.com/shopping/product/12511021881998705944?lsf=seller:3074108
,store:3197459900599705809&prds=oid:3937850440998956632&q=amber+power+steering+fluid&hl=en&ei=MeHyWs2kD4n4_Abh0YTgDw
May 8, 2018 at 9:55 PM
JIS001
That should be fine.
May 8, 2018 at 11:13 PM
Add image or video
Ask a new question
Check engine light
Engine won't start
