Power steering fluid flush
82,000 MILES • 3.0L • 6 CYL • 4WD • AUTOMATIC
JOHNB906
I've got 82,000 miles on my car listed above (SL)). My repair place says I need to flush my power steering fluid. Does this sound right from a mileage basis? Also, how much should such a procedure cost me? I'm in the 53590 zip code area.
Sep 6, 2019 at 5:39 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
I've never bought in to having that or a brake fluid flush. The only real reason I would suggest having either of those two services done is if there is major contamination due to a failure or a leak of some kind. Unless it's giving you a problem just maintain your fluid levels and save your money.Hope this helps and thanks for using 2CarPros.
Danny-
Sep 6, 2019 at 11:09 AM
