Power Steering Fault Assist message
36,000 MILES • 5.0L • V8 • AUTOMATIC
CARRIEBREDOW
Periodically (it's happened 10 times since December), when backing up out of a tight parking space where I need to turn my wheel all the way, the wheel suddenly locks up and a warning message pops up on my info display that says "Power Steering Fault Assist". My owner's manual tells me to put my car in park and turn it off for about 15 seconds, then turn it back on. This has worked for me every time, and the message disappears and I drive off like normal. I took my car in to the Ford dealership to diagnose the issue last week, and they said I need a new electric steering rack, which is $2,100.00. I did some research online, and I am not experiencing any of the symptoms for a failing electric power steering rack, and also read that mechanics often resort to this solution when they cannot figure out why the Power Steering Fault Assist message appears. My question is, could there be another problem, like a glitch with the computer system that generates this error, or?
Jul 24, 2019 at 7:15 AM
  • 55,616 POSTS
Yes this could be a sensor issue but to be sure lets run the CAN scan to see what comes up here is a video to help see how its done.
https://youtu.be/InIlnsjOVFA
If it is the power steering motor here is how it is changed out. Check out the diagrams (Below). Please let us know what you find. We are interested to see what it is.
Jul 26, 2019 at 4:25 AM
CARRIEBREDOW
Thank you so much for the reply! I will need to ask the dealership if they ran a CAN scan.
Jul 26, 2019 at 4:55 AM
  • 55,616 POSTS
Yep, the CAN scan is how things are done now, please let me know how it turns out ;)
Jul 27, 2019 at 3:31 AM
CARRIEBREDOW
I called the Ford dealership yesterday and asked if they did the CAN scan, and they did. It is how they found the codes and determined the need for the electric power steering rack replacement. Thanks again!
Jul 27, 2019 at 3:54 AM
  • 55,616 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Jul 27, 2019 at 5:09 AM
