Power steering failing when braking?
325,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
EDWILLIAMS2018
First time I've run into this issue in decades of working on cars. When I hit the brakes the power steering goes out. After releasing the brake and revving the engine, it comes back. Any idea? 1D7HU18D13S307275
Mar 11, 2023 at 9:20 AM
BRENDON S
  • 653 POSTS
Good morning, EDWILLIAMS2018,
I found a TSB on a revised power steering system bleeding procedure. It sounds like it might have some air in it. I am adding this TSB for you. I would give it a shot at the very least to rule it out.
When you are hitting the brakes is the vehicle sitting still or are you in motion?
I would try the bleeding procedure and go from there.
Thank you,
Brendon
2CarPros
Mar 11, 2023 at 10:04 PM
