I own the car listed above rt 100th anniversary RWD.
I'm having issues with my suspension. so over a course of a month I've replaced everything new. I've come to my issue that my rack and pinion could be out of alignment or damaged within. I'm not sure. Hoping it is something I can fix.I do have play in my rack and pinion. The noise is on the passenger side. Turn left is fine. Then right is tight. If I hit a bump my wheels go right. My rack has no leaks. I posted a video of the noise.
https://youtu.be/scDFkp8kWTw
I've installed all new parts.
Bilstien struts front and rear.
New strut tops.
All new control arms.
New inner and outer tie rods.
Lower ball joint.
New wheel bearings.
New links.
New sway bar bushing.
New brake kit.
Everything has been greased.
Alignment.
Same for rear all new adjustable control arms. except for the lower cradle.
Suspension has been torque correctly under the weight of the car.
Thank you
New strut tops.
Lower ball joint.
New wheel bearings.
New links.
New brake kit.
Alignment.
Thank you
Jul 24, 2020 at 4:24 AM
